| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Apr 2011 Location: Pennsylvania
Rep Power: 0 ![]() ![]() Thanks: 16
(Thread Starter) | Neutral : +1 score now i'm thinking i'm disappointed with the performance and sound because it isn't hitting boost targets. not even close. it's on a stage 1 map and peaks at a little over 13 and runs a stable 11lbs at WOT. he had reflashed it last night and that didn't change anything. if someone could take a look at the logs and make a few recommendations it'd be awesome! thanks guys |
| Not Ranked : 0 score I would definitely recommend that your friend get on a tuning list (in no particular order) -@phate and @Bucker -@atvfreek (freek tunes) -Perm tuning list That being said, the first thing that I think you can do safely is raise the throttle requested load - per gear tables (normal bat only) to a value of 2.1 or so from 2500rpm -redline. Last edited by rfinkle2; 11-17-2011 at 08:58 AM. |
(Thread Starter) | Not Ranked : 0 score so you're confident it's all in the tune? i should have him flash it stock and get a log of that. |
![]() Join Date: Jul 2011 Location: Chattanooga, Tn
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,192
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score This sounds like a good idea to me.
__________________ [SIGPIC][/SIGPIC] 2006 Mazdaspeed6 BCM GT MODS : Cobb AP // Cobb SF // Sure TIP // JBR RMM // JBR SSB // JBR SSP // Magnaflow CBE // MSR 045 18 X 8 +35 // ACT ZX5-HDG6 // M2 3" catless DP // AT HPFP Internals // NGK's -- FREEKTUNE in progress Having a 12 second Honda is just like coming out of the closet; You're going to surprise a bunch of people, but in the end you're still gay. |
| The Following User Says Thank You to greenespeed For This Useful Post: | tar0s (11-17-2011) |
![]() Join Date: Jan 2010 Location: Rosemount, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 946
Groans: 53
| Not Ranked : 0 score How does the car drive in vacuum? He could have a boost leak as well.
__________________ You know.... Moose stuff |
| Not Ranked : 0 score Looking @ the wgdc, I'm 90% sure it is the tune, although a moosenamedhank could have suggested an additional problem. |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | tar0s (11-17-2011) |
Groans: 53
| Not Ranked : 0 score maybe.... maybe not. I just think it's always a good idea to try and rule out any mechanical issues before you start digging into the tune. Unless it is obviously the tune.
(Thread Starter) | Not Ranked : 0 score gotcha. will get a log up tonight. we're stuck at our 9-5's. |
If you look @ what happens when the load becomes high, the wgdc is hacked down, sometimes to zero. | |
| Not Ranked : 0 score I noticed the WGDCs also but don't know enough about it all to say anything. My initial thought was that it's low all across the board.
![]() Join Date: Nov 2010 Location: Manchester, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score Speed 6 ots tunes are terrible IMO, but I would still flash to stock and see what happens. I also noticed that the maf cal is off by 12% that would cause an incorrect calc load reading and reduce boost drastically.
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
| The Following 3 Users Say Thank You to atvfreek For This Useful Post: |
| Approved MSF Vendor ![]() Join Date: May 2008
Rep Power: 2548 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
1) The AFR's are inconsistent and lean occasionally going into WOT. A Boost leak somewhere is very possible based on the boost he's getting (only 10PSI) 2) The WGDC logs looks like a classic Boost solenoid issue - be it wiring, vacuum reference lines, or a bent actuator arm. 3) Your MAF volts are telling me that either it isn't scaled right or you have a lot of air not flowing through the MAF - possibly a post MAF air leak as well. I'd really look into the mechanical health of the car, because those logs are not showing a very healthy setup. -David@COBB | |
| The Following 6 Users Say Thank You to Cobb Tuning For This Useful Post: | amoosenamedhank (11-17-2011), greenespeed (11-17-2011), rfinkle2 (11-17-2011), SJP0tato (11-19-2011), super_pablo_ (12-15-2011), tar0s (11-18-2011) |
![]() Join Date: Oct 2011 Location: Diamond Bar CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
| Not Ranked : 0 score i would clean your maf sensor, and recalifbrate. Before that, check all hardware; clamps, hoses, to see. I would do a boost leak test to see if you're boost leaking. Like what david say, your logs does not look healthy
__________________ -2014 Evo X GSR -2007 MAZDASPEED 6 (SOLD) BNR S3// ALL-SUPPORTING MODS |
![]() Join Date: Dec 2009 Location: Minneapolis, MN
Rep Power: 390 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,607
| Not Ranked : 0 score Definately take the advice of some of the people above me, (finkle and cobb especially), but to me I see a poorly scaled MAF: -13 LTFT. This appears to be causing an inflated reported load and g/sec readings. If you scale the load values down 13% you end up holding about 1.6 after your initial spike. If I recall, most of teh stage one OTS maps target right around that load. Currently in stock and OTS form (MS6 at least) the car is targeting a load value, not boost. If you are at your load target, the car doesn't really care what the boost is. 15 or 10 psi doesn't matter. To me, if you had a post turbo leak, I would expect higher WGDC as the car tries to push more boost/load to compensate for the leak. So, to reiterate what others have said, first make sure you are in good mechanical order. After that you need to do a proper MAF cal and then go in and either up the load targets or switch to boost tuning and up those targets. Good luck and dont' blow it up, lol
__________________ 2006 BCM MS6 GT CS SRI/TIP Jbarone SSP/bushings cp-e RMM, TMIC, Stiff Diff AP KMD V2.whatever Ebay Catless DP Grom Ipod |
Atvfreek has helped me quite a few times, so don't dismiss his advice. | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | tar0s (11-18-2011) |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
| Not Ranked : 0 score I am 99% on the Load error comp table being an issue here. My first step would be to tear the entire intake system down to the Throttle body and make sure it is put back together properly, then jump on the tune. It needs a MAF cal and an actual tune.
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot |
(Thread Starter) | Not Ranked : 0 score awesome info all around. he wasn't able to do a stock tuned log last night. thank you all (cobb is freakin' awesome for reaching out) and we'll definitely keep everyone posted. i'm sure i'm not the only one who's upset about a speed6 not feeling too well. :p |
| The Following User Says Thank You to tar0s For This Useful Post: | rfinkle2 (11-18-2011) |
(Thread Starter) | Not Ranked : 0 score we're gonna take the intake completely off, clean the sensor / filter tomorrow night. anything else you guys suggest we check while at the shop? |
| Not Ranked : 0 score With a car that has had a turbo underhood for years, all vacuum hoses and boost related hoses are suspect. Once you get everything worked out mechanically... Do an maf calibration and focus your initial efforts on the trl - x gear (norm bat) tables. |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | tar0s (11-19-2011) |
(Thread Starter) | Not Ranked : 0 score Alright! So they got the sensor cleared out (had a nice layer of dust), double checked all the clamps, peeked in on the filter and my god was that dirty. they dusted it off and he's gonna be ordering a new one but it should last. Also uninstalled / reinstalled the AP with the latest firmware, he got it flashed to the mazdaspeed cai 2 map (with air straightener) and my god is are the logs better. night and day. thanks all for the quick support and ideas. think this is a mix of car needing some loving and getting the right map on there. |
| Not Ranked : 0 score Is he still getting a surging feeling? |
(Thread Starter) | Not Ranked : 0 score how do you mean? i've heard nothing bad, only that it's much more responsive. |
| Not Ranked : 0 score I see in his logs a few times where his wgdc is cut down pretty substantially (not in between shifts). I'm surprised he didn't mention a studdering feeling. |
| Not hitting boost targets again (AP).. | dsmluck | MazdaSpeed 3/6 - ECU Computer Tuning | 28 | 08-01-2011 05:35 PM |
| now im not hitting full boost.. grrr | TheFranchizeSLB | 2010 MS3 - Turbo Induction | 9 | 11-29-2010 02:21 PM |
| Not hitting full boost | Post pwned | 2010 MS3 - Turbo Induction | 10 | 11-28-2010 01:22 PM |
| ideally whats the best boost targets for custom tune from full boost to redline? | Wenis Prinkle | Cobb ATR Support | 26 | 08-24-2009 06:36 PM |
| Not hitting boost targets, Underboosting | spheed3 | Cobb ATR Support | 17 | 08-09-2009 12:24 PM |
