 Old 12-29-2009, 10:43 AM   #1
RocketScientist's Avatar
Posts: 71   (View Stats)
RocketScientist has a spectacular aura aboutRocketScientist has a spectacular aura aboutRocketScientist has a spectacular aura about
Default STOCK engine parameter recordings
I'm in the process of recording data from my bone stock 2008 MazdaSpeed3 before I pull the motor for a full build. I have a number of files saved which I send to anyone interested. I plan to start pulling the motor tomorrow so if anyone could use some data I have not collected please respond or PM me.
The car has 1400 miles on it so it should be good quality data. I'm in Florida where the weather has been in the 50's with 45% to 70% RH. The runs have been done on the street so I have been limited to about 80mph. Full throttle starts, constant cruise and boost at speed. I've seen up to 16psi boost so far.
RocketScientist is offline   Reply With Quote
engine build with stock compression Jessed87 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-12-2009 11:55 PM
hows your stock engine? johnac08 MazdaSpeed 3/6 - Turbo Induction 4 03-31-2009 02:16 AM
Safe Horsepower on stock engine build? cl45music MazdaSpeed 3 - Engine, Transmission & Driveline 36 02-17-2009 07:27 AM
Stock pump looks OK on stock engine enganear MazdaSpeed 3/6 - ECU Computer Tuning 33 04-08-2008 09:21 AM
Page generated in 0.22294 seconds with 20 queries
