 Old 08-17-2018, 05:23 PM   #1
Analytical's Avatar
Posts: 42   (View Stats)
Analytical will become famous soon enough
Groaned at 6 Times in 2 Posts
Default Stock tuning map to pass smog
Does anyone have a stock map I could have to use for my smog? I'm running only upgraded fuel pump & intercooler but OTS tune so I can't pass.
Thanks.
Tricks get applause, style gets respect.
Analytical is offline   Reply With Quote
The Following User Says Thank You to Analytical For This Useful Post:
monkey.bones.007 (08-17-2018)
 Old 08-17-2018, 07:22 PM   #2
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Im assuming you did this with an AP, you just need to flash back on the same AP to your stock map. It should be easy.
Thanks.
Tapatalk, it sucks for free!
 Old 08-17-2018, 07:25 PM   #3
Mattyhawk1's Avatar
Posts: 739   (View Stats)
Sorry, why can't you pass? I have been smogging my car with only a downpipe cat (gutted 2nd cat), Corksport TMIC, Corksport Intake and my own tune. As long as you don't turn off your sensors and you pass visual, you are good.
Monkey! What up! Long Time...
Last edited by Mattyhawk1; 08-17-2018 at 07:25 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Mattyhawk1 For This Useful Post:
 Old 08-17-2018, 07:34 PM   #4
How you doin?
I was keeping it easy for them and letting em know they can just flash back with the same ap they used to flash the ots tune. At this point on the forums if you complicate the response they get confused.
 Old 08-18-2018, 08:02 AM   #5
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Will this map work?
MECP
2012 BM
Rfinkle tune in progress
The Following 2 Users Say Thank You to 5doorsoffury For This Useful Post:
monkey.bones.007 (08-18-2018), Thor Hammer (08-20-2018)
 Old 08-18-2018, 06:04 PM   #6
Analytical's Avatar
It was flashed w/ ap but i didnt save the stock tune when i installed the ots tune.
 Old 08-18-2018, 08:56 PM   #7
I'm pretty sure it automatically saves your stock tune. Plug your ap in and see what it says for tunes.
 Old 08-18-2018, 10:24 PM   #8
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
The OTS tunes are usually unchanged or slightly changed in the closed loop sections comparing to the stock tune. So there is absolute no way you can't pass smog test with an OTS tune unless you have other modifications as well (EGR delete, removed cats). You have a different problem.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 08-19-2018, 01:49 AM   #9
Analytical's Avatar
I do have several codes popping up that won't seem to go away after clearing. I'll post them up tomorrow. I just didnt want to put it on machine if I'm going to blow shit.
 Old 08-19-2018, 06:56 AM   #10
Groans: 74
When you flash a map Communication codes come up but are checked off in the section that hides codes.Thats it . If you flash a fresh stage 0 tune with the appropriate intake and you still get codes makeing the engine light come on you have something wrong. Btw stage 0 is as close to stock as possible. I passed with all the mods in my sig and my e85 tune loaded up.
MECP
2012 BM
 Old 08-20-2018, 02:37 AM   #11
mituc's Avatar
Groans: 111
I'm passing smog test with my 450-470bhp tune and I don't even bother making any changes or taming it down, not even in closed loop where I upped the timing and leaned the AFRs a bit (not above stoich though).
The functional EGR and the two high-flow cats is all that I need apart from the tune which is not crazy in CL.
 Old 09-08-2018, 07:47 PM   #12
Analytical's Avatar
So Im getting 2 codes holding me back, P0108 & P0098. My hope is after swaping in my bosch 3 bar map sensor I'll be good.
A few other codes that have popped up engine wise are
P0304
P0069
P0234
I get an occasional IC2064 also.
 Old 09-09-2018, 12:37 PM   #13
mituc's Avatar
Groans: 111
You could always flash a stock tune with the proper sensor calibration in (MAP and MAF).
Tuning and CA Smog test chomorro MazdaSpeed 3/6 - ECU Computer Tuning 50 08-31-2016 11:11 PM
CA SMOG, FMIC, WMI - PASS mazdas4me Mazdaspeed3/6 General Discussion 4 06-13-2015 06:06 PM
Catted dp: does it pass smog? FoolioABC MazdaSpeed 3 - Engine, Transmission & Driveline 38 08-13-2008 06:43 AM
Page generated in 0.31619 seconds with 24 queries
