 Old 03-08-2011, 12:09 PM   #1
bayarea_pat's Avatar
Posts: 120   (View Stats)
bayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond reputebayarea_pat has a reputation beyond repute
Default SURE Datalog
I'm running the 91 octane Stage 1+ SF Intake map with SURE Aeros and Sidewinder along some other minor mods in my sig. I did a search and couldn't really find any other logs for this setup or SURE products in general.
This is without MAF calibration and it still looks pretty good to my knowledge. Looks like i'm getting some boost spike but from what i've seen it is typical of the mods I have. Also the AFR's seem to be fluctuating a bit.
Just wanted to make sure everything looks ok. This is my first time ever dealing with ECU stuff.
And hooray for having decent fuel pressure so far with 62k miles. Might have to pick up a TMIC or TP and try a stage 2 map
*oh and there is 120 miles on the reflash so far*
---2008.5 MGM Mazdaspeed 3--- SURE Aeros & Sidewinder - OBX Test Pipe - JBR SSP, RSB, 88A RMM - Turbosmart BPV - ETS TMIC Autotech FP Internals - ~~Getting Dizzy~~
bayarea_pat is offline   Reply With Quote
 Old 03-08-2011, 12:36 PM   #2
the_caruch's Avatar
Posts: 698   (View Stats)
the_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the world
you had a brief dip to <1600psi but looks like it was because of the 20psi spike.
i wouldn't run a stage 2 map without getting an upgraded pump.
cp-e CAI, cp-e Turbo Inlet, cp-e catted DP, cp-e HPFP, cp-e flashes, cp-e Standback w/PNP, cp-e FMIC, TRZ RMM, TS Compact BOV (full re-circ), DDM 55W 6k HID's, Cobb RSB. HKS Hi-Power Exhaust, OCC
the_caruch is offline   Reply With Quote
The Following User Says Thank You to the_caruch For This Useful Post:
bayarea_pat (03-08-2011)
 Old 03-08-2011, 06:03 PM   #3
R.MS3's Avatar
Posts: 987   (View Stats)
R.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the world
TP is not enough for a stg2 map and you would need upgraded FP as well.
Looks like you're not entering OL soon enough, typical problem with OTS maps. Visit the Cobb ATR section and look on one of the stickies for the tables you need to change in the CL section of ATR.
R.MS3 is offline   Reply With Quote
 Old 03-13-2011, 07:41 PM   #4
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Yeah fuel pump takes a shit at 9.4 seconds.
 Old 03-28-2011, 04:36 PM   #5
So i'm gonna bump this thread back up. Since the first logs I calibrated the MAF and changed the OL/CL settings according to the sticky.
Here is another log of a 3-4 shift with FFS. I'm concerned with the knock and AFR after the shift. 3rd seems ok and the boost spike seems to be gone after the change.
Any ideas with the fluctuation in AFR from 3rd to 4th? i'm confuzzeddd
 Old 03-28-2011, 04:37 PM   #6
oops forgot to attach it... phail
there we go
 Old 03-28-2011, 04:54 PM   #7
R.MS3's Avatar
Your MAF calibration is not right? Is it a smooth curve all the way up? That can be your only reason or a huge leak.
Your AFR's are dangerously high, if you rode on that map for a good 30 miles and did that log, i wouldn't advise running that map again. I would try one more and see how your AFR's behave.
I would go back to the previous MAF calibration if it doesn't work out or have someone calibrate it correctly.
The Following User Says Thank You to R.MS3 For This Useful Post:
bayarea_pat (03-28-2011)
 Old 03-28-2011, 05:01 PM   #8
Yeah the MAF graph is a smooth curve. I'll go check the calibration again. I'll attach the map, the only thing I touched was maf, ol/cl, ffs and lc.
thanks for the input
 Old 03-28-2011, 05:06 PM   #9
R.MS3's Avatar
Could be your ffs/lc settings that might be screwed up as well since you have good AFR before the shift. Try revising that.
 Old 03-28-2011, 05:45 PM   #10
quick 4th gear only(was cut short) and MAF run. LTFT off by -2.5 majority of the time.
edit: added 2 logs of new tune. again with high afrs after a 3-4 shift hmmm could it be the bpv?
 Old 03-28-2011, 06:20 PM   #11
R.MS3's Avatar
Edit: v108d4 uploaded!
 Old 04-10-2011, 04:52 PM   #12
Heres a log using the version b tune. 3-4 shift looks a lot better now.
edit: adding two moar logs with the stock bpv on... one 3-4 shift and one straight 4th gear pull
Datalog tozfeekum MazdaSpeed 3/6 - ECU Computer Tuning 13 04-01-2010 12:43 PM
First AP datalog @ WOT dougefresh_ MazdaSpeed 3/6 - ECU Computer Tuning 14 03-26-2010 06:54 PM
Little help with my datalog please Stockturbo_Ms3
Cobb ATR Support
12 02-22-2010 09:31 PM
how to datalog blackwidow Custom Performance Engineering (cp-e.com) 1 07-15-2009 07:27 PM
My first Datalog Derek88 MazdaSpeed 3/6 - ECU Computer Tuning 18 03-10-2008 12:02 PM
Page generated in 0.32699 seconds with 24 queries
