 Old 12-22-2008, 10:34 AM   #1
johnac08's Avatar
Posts: 141   (View Stats)
johnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud of
Default Tune day. knock retard after 5000rpm
i had my car tuned this saturday but it didnt really work out even w/ tuning.
i had it tuned by church. issue was car is knocking after 5000rpm. he said that the car knock sensor might need to be replaced. he said that he doesnt see anything on the datalog that causes it. he even pulled some timing and still getting the same knock degree. We are assuming that its the knock sensor. i also read about it saying its too sensitive.
i made 277whp @ 5381rpm (18psi). Kinda dissapointed about it. i think he stops after knock is being detected because its already retarding timing.
earlier this morning. i tried to put some cushion on top of the knock sensor because i think its hitting some wires around that area. also tightened some bolts around there. it still knocks. i think up to 4 degrees. i have to double check w/ church tomorrow how much knock the car was getting. ill try some octane boosters tomorrow to see if its gonna get rid of it.
maybe i need a High pressure FP
tune for now really made a difference it pulls hard till 5500 then knock(huhu)
is there already an aftermarket sensor for the car?
what do u guys think i should do? HELP!!!!
2007 MAZDASPEED6 GT Liquid Platinum Metallic
ENGINE MODS: CPE FMIC, CPE FullControl Flash, ATP Downpipe W/ High Flow Cat, CPE Dual Exhaust, CPE Xcel™ CAI, HKS SSQV BOV, DNP Turbo Manifold, ProSport Ceramic Header Wrap, Speedie6 Inlet Pipe, SU Recirc Tube. CPE Engine Mount, CPE Standback w/ PNP, WOT Box Full Throttle/2Step, HKS Twin Power Ignition System, Denso 2Step Colder Plugs, Redline Tuning Hood QuickLift:Elite, Greddy Catch Can, Spin-On Oil Filter Conversion Kit, Mobil1 5w-30 FullySynthetic, Redline MT-90
INTERIOR MODS: MSD Dashhawk, TWM SS Stage 2 w/ Bushings, 52mm VEI Boost Gauge, 52mm Vent Pod
EXTERIOR MODS: VG Sharkfin Antenna, 18" 5ZIGEN 5ZR Wheels 43+ Offset with 225/40/18 TR1 Toyo Tires
johnac08 is offline   Reply With Quote
 Old 12-22-2008, 11:24 AM   #2
dread's Avatar
Posts: 1,223   (View Stats)
dread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the world
get some logs of the knock and people will be able to tell you whats going on.
[SIGPIC]http://i163.photobucket.com/albums/t318/dreadedhero/DSCN2058-2.jpg[/SIGPIC]
2007 ms3 sport black mica completely stock
dread is offline   Reply With Quote
 Old 12-22-2008, 11:44 AM   #3
MTuning's Avatar
Posts: 362   (View Stats)
MTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond repute
Groaned at 16 Times in 8 Posts
yea i wouldn't go back until you get an upgraded CDFP
MTuning is offline   Reply With Quote
 Old 12-22-2008, 12:30 PM   #4
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
i'd say you definately need a high pressure cdfp, with all those mods. i needed one after i added downpipe and 3.25" tmic.
 Old 12-22-2008, 02:52 PM   #5
johnac08's Avatar
just did 2 logs right now.
1st run
didnt have that much knock not sure why? might be related to temperature.
2nd run
theres the knock.
how come my afr doesnt drop as my fuel pressure drops?
Do i really need a better pump?
 Old 12-22-2008, 03:49 PM   #6
bova's Avatar
Groans: 45
not sure why it doesnt' go leaner but just doesn't. you are in need of a pump though.
 Old 12-22-2008, 08:11 PM   #7
dread's Avatar
my god that tune is not looking good. you need a fuel pump stat. Your a/f doesn't go leaner because your car is probably closing the throttle plate to prevent your engine from blowing up. That is if your flash is not preventing this safety function of the ecu from working. You may be able to prevent the pump from crapping out by leaning out the a/f ratio to 12:1, but your better off getting the pump.
 Old 12-22-2008, 08:18 PM   #8
phailerider's Avatar
Posts: 4,639   (View Stats)
your tune is adding WAY to much fuel down low. im surprised your not cutting.... dumping fueldown into the 9's like that during spool.
and what have you done with your timing on that tune too?
 Old 12-22-2008, 08:23 PM   #9
dread's Avatar
Yeah I would find a new tuner. Actually I would just tune it myself if I had a standback.
 Old 12-23-2008, 01:15 AM   #10
johnac08's Avatar
i did 3 more runs tonight. all runs were in 3rd gear
1st run
car just reach normal engine temp when i did this run. noticed that i didnt have that much knock?
2nd run
3rd run
noticed that im low on coolant. maybe thats why im getting more knock when engine is hotter.. i will top it off tomorrow
i will order cpe hpfp tomorrow
my timing down low were 1.5
 Old 12-23-2008, 07:30 AM   #11
dread's Avatar
good move on the fuel pump. Now stop going WOT until you replace it.
 Old 12-23-2008, 10:57 AM   #12
Speedn3's Avatar
Posts: 642   (View Stats)
Speedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond repute
Looks like your knock starts as soon as the fp drops.
2008 MS3
Forge BPV, COBB SRI, AP ATR Stg 2+SF v107 FMIC, RPMC turbo inlet, Exhaust Depot DP, CP-E CBE, KMD internals, TT, DH, OF conversion, TRZ Poly mount, Exhaust Depot FMIC,TWM ss w/bushings, ITV22, AIS meth injection
Speedn3 is offline   Reply With Quote
Knock Retard Analysis Speedy3 MazdaSpeed 3/6 - ECU Computer Tuning 109 09-16-2014 02:18 PM
Knock retard.. gone Doc MazdaSpeed 3 - Engine, Transmission & Driveline 5 11-06-2008 11:45 AM
Knock retard Lex MazdaSpeed 3/6 - ECU Computer Tuning 18 09-03-2008 08:24 PM
Knock retard guestion.. SharkDiver
Cobb Access Port/Maps
0 08-22-2008 11:55 PM
Knock retard!!! Eazy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 07-12-2008 05:35 AM
Page generated in 0.31530 seconds with 25 queries
