 Old 01-09-2009, 05:11 PM   #1
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Default V1.03 Calibrations Now Available for Mazdaspeed3 AccessPORT
OBB Tuning is happy to announce that V1.03 AccessPORT Maps for the Mazdaspeed3 are now available for download.
These new calibrations from COBB Tuning provide the following improvements:
- Increased threshold for cold weather fuel cuts
- Improved boost control parameters to hold more boost towards redline
- Modified fueling and ignition tables
- Extensive updates to improve power output
Please read the map description once you have downloaded and installed it on your AccessPORT for additional map details. PLEASE use the AccessPORT to verify that your Camshaft Driven Fuel Pump (CDFP) is able to keep up with new fueling demands before you drive aggressively. The variable "Fuel Pressure DI" should not drop below 1300psi while at WOT. If your fuel pressure drops below this level while at WOT and while running an AccessPORT map, then you will likely need a CDFP upgrade in order to run the map.
These maps can be downloaded immediately from the COBB Tuning Support Page. A new firmware upgrade will be available on Monday, January 12, that will automatically install all of the new V1.03 maps on your AccessPORT.
Enjoy your weekend!
Gary Sheehan
Director of Marketing
COBB Tuning
The Following 3 Users Say Thank You to Cobb Tuning For This Useful Post:
aragorn764 (01-10-2009), itzl0l (01-09-2009), skeeter149 (01-09-2009)
 Old 01-09-2009, 05:15 PM   #2
Ferdball's Avatar
Posts: 1,340   (View Stats)
Ferdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the world
Where are the map notes?
Ferdball is offline   Reply With Quote
 Old 01-09-2009, 05:18 PM   #3
Derek88's Avatar
Posts: 773   (View Stats)
Derek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the world
Will any of these get rid of the catalytic converter and the U20XX codes that I have been getting on the beta maps?
-Derek
No longer in the Mazdaspeed Family
Derek88 is offline   Reply With Quote
 Old 01-09-2009, 05:22 PM   #4
itzl0l's Avatar
Posts: 462   (View Stats)
itzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond reputeitzl0l has a reputation beyond repute
^^^^^^^^^^not yet im guessing
07 cb Ms3 - MS cai / Vibrant exhaust / TurboXS DP / Cobb AP - trapped 107
TOTALED 11/2/09
04 SRT4 - sold - trapped 120+
itzl0l is offline   Reply With Quote
 Old 01-09-2009, 05:22 PM   #5
y2kc0wb0y's Avatar
Posts: 808   (View Stats)
y2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the world
Who will be the first to log a 4th gear run?
y2kc0wb0y is offline   Reply With Quote
 Old 01-09-2009, 05:54 PM   #6
wassup61's Avatar
Posts: 1,232   (View Stats)
Im betting this shit still boost cuts the shit outa itself at 18deg F. I just made a 4th gear log that pulled harder than 103j 2+ 93 octane FMIC (21psi, 12.5 AFR) with only 17 psi and 11.75 AFR with NO CUT at 8 deg F
All wagon, No traction
COBB AccessPORT for 2009 Mazdaspeed3 Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 8 02-18-2009 02:41 PM
Page generated in 0.26658 seconds with 25 queries
