Like Tree7Likes
 Old 11-03-2014, 01:38 PM   #1
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Steve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the world
Default VersaTuner v1.9 Released!
VersaTune is proud to announce the release of VersaTuner 1.9. This new release includes the following exciting new features:
All Platforms:
A major refresh of the Tune Editor:
Enhanced user interface
Change tracking
Tune comparison
Table name search
Improved 3d table render manipulation
Table group names with changed tables relative to the selected comparison tune are displayed in bold text.
Tables with changed cells are marked with an asterisk in the table list.
You will be prompted to save a tune with unsaved changes when exiting Tune Editor.
Datalog Autosave – Datalogs now auto save with an automatically generated name based on the current date and time, ie Data log - 11/3/2014 8:36:38 AM. Simply press the space bar to start and stop logging in the dashboard tab. Logs will automatically be saved and the dashboard will remain active after logging stops. We hope this increases the safety of datalogging by eliminating the need to enter and accept a log name.
Mazdaspeed6/Mazda6 MPS, Mazdaspeed3,Mazda3 MPS, Mazda CX-7:
Torque Limit Disable – FINALLY!!! You can now disable all torque limiters, including traction control and torque vectoring due to steering angle sensor (SWAS) input. This feature is enabled via a new check box in Tune Customizer.
Mazdaspeed6/Mazda6 MPS, Mazdaspeed3,Mazda3 MPS:
MegaSpool – A Mazdaspeed/Mazda MPS tuning first. Now even the biggest turbos can be fully spooled at launch. MegaSpool provides configurable timing retard during Launch Control and No-Lift-Shift. This feature is configured in Tune Customizer.
Bug Fixes:
Miscellaneous table axis and label bug fixes.
Fixed a bug in EUDM and AUDM Gen2 Mazda3 MPS Launch Control/No-Lift-Shift which prevented it from activating.
Fixed checksum bug in 2010 AUDM Mazda3 MPS stock ROM.
VersaTuner now refreshes the local tune database listing after new tunes are saved.
General performance improvements – screen load times, etc.
Information and ordering at https://www.versatuner.com
2.0t03speed likes this.
Steve
Lead Tuner
Steve@VersaTune is offline   Reply With Quote
The Following 19 Users Say Thank You to Steve@VersaTune For This Useful Post:
2.0t03speed (11-03-2014), ArmanRus (11-03-2014), Code Monkey (11-03-2014), Justin@Freektune (11-03-2014), kgb (11-04-2014), Koke382 (11-03-2014), Lex (11-03-2014), Mazdazilla6 (11-03-2014), Micha (11-04-2014), Nliiitend1 (11-03-2014), phate (11-03-2014), Roddiy (11-09-2014), SarcasticOne (11-03-2014), shadesofgray19 (11-03-2014), speed23 (11-03-2014), SpeedRebirth (11-03-2014), TiGraySpeed6 (11-03-2014), WetzMS3 (11-03-2014), [R]usty (11-03-2014)
 Old 11-03-2014, 02:38 PM   #2
skiptowncat's Avatar
Posts: 1,592   (View Stats)
Shame I just got rid of my car.
Tuned with by
 Old 11-03-2014, 03:12 PM   #3
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Please tell me you guys will be offering a Black Friday sale. The stutter fix had me on the edge of making the switch from the AP but now I'm ready to jump.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 11-03-2014, 04:08 PM   #4
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Originally Posted by Steve@VersaTune View Post
Change tracking
Tune comparison
I've been using Megasquirt 3 quite a bit in the past year or so and I love the tune comparatar. Change tracking sounds awesome, can you explain what or how it displays the changes and if tune "notes" are somehow associated with those.
SWAS removal - awesome. Ignition cut LC and FFS - awesome. Not to mention you've had the shift stutter fixed in the MS6's for a long time now...
I'd really like to hear some experiences with these features because they sound great. We're pretty much done racing for the season, here, but I'll likely be making the switch to VT before the start of next season.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 11-03-2014, 04:09 PM   #5
leka's Avatar
Posts: 144   (View Stats)
leka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to behold
what should i choose in the LC ignition retard? -22?
I got GTX2867 stock block
leka is offline   Reply With Quote
 Old 11-03-2014, 04:29 PM   #6
-22* works well for stock K04s. I tested all the way to -45*. If you go too far the engine just won't rev. Too little, and it will hit the limiter without building enough boost.
Try -22 or -25 and log it. If you are sitting on the limiter and not hitting the boost level you want, add more retard (more negative). If it's too slow to rev up, add some positive timing (less negative). It's a balancing act between retard and rev limit. When it's right, you should see the boost control solenoid working to control boost with the wastegate while you sit at a comfortable rev limit.
You shouldn't need to use stratospheric LC rev limits any more to get big turbos to spool.
Steve
Steve
Lead Tuner
The Following 5 Users Say Thank You to Steve@VersaTune For This Useful Post:
Koke382 (11-03-2014), leka (11-04-2014), Rich990 (11-20-2014), Roddiy (11-09-2014), skiptowncat (11-03-2014)
 Old 11-03-2014, 06:00 PM   #7
Great to see this update Steve - I have customers very eager to play with the new features!
We are a distributor of VersaTuner so if anyone is looking for a tune+VT bundle, get in touch.
leka (11-04-2014), SpeedRebirth (11-03-2014)
 Old 11-03-2014, 08:03 PM   #8
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
Some porn for ya! =) @phate;
Tune Customizer
Tracking changes; You can see a * before the table name (Speed Limiter - Throttle Close)
Tune Comparing; Table names that are bold have different values between the tunes.
You can also see that the actuall values in the table are also bold (16.67, 10, 33.33, 20, 50, 30).
Current tune can also be compared with OEM and "Since Last Save"
Searchable tables
Added savepage with different design
Better design on the list of logs
VT just became a serious competitor =) And Steve also said that more updates are to come and they will arrive much more frequently
Roddiy and Koke382 like this.
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
The Following 13 Users Say Thank You to SpeedRebirth For This Useful Post:
Code Monkey (11-04-2014), cshunter (11-03-2014), Deldran (11-03-2014), Easter Bunny (11-04-2014), Koke382 (11-03-2014), Mazdazilla6 (11-03-2014), Micha (11-04-2014), Nliiitend1 (11-04-2014), phate (11-03-2014), Roddiy (11-09-2014), SarcasticOne (11-03-2014), TiGraySpeed6 (11-04-2014), torquemaniac (12-29-2014)
 Old 11-03-2014, 08:14 PM   #9
Koke382's Avatar
Posts: 4,361   (View Stats)
Groans: 32
Whuuuuuut nice
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
 Old 11-03-2014, 08:21 PM   #10
Eth Fiend
phate's Avatar
Very cool, thanks @SpeedRebirth.
-06 MS6
 Old 11-04-2014, 09:51 AM   #11
There's a bit of talk going on in another thread and some good topics were brought up @Steve@VersaTune. What can we expect in future updates? Are there fuel scalars for E85?
Also on your website it says that minor updates are free. Does that mean we will need to pay more if a V2 (aka major update) comes out?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
Koke382 (11-04-2014)
 Old 11-04-2014, 09:58 AM   #12
I am working on an E-85 How-To right now. If any additional tables are needed, they will be added in the next release.
We have not had a major release yet that we have charged for. We understand that it's a competitive market and we need to continue to provide value to our customers.
Mazdazilla6 likes this.
Steve
Lead Tuner
The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post:
Mazdazilla6 (11-04-2014), Micha (11-04-2014)
 Old 11-04-2014, 10:00 AM   #13
leka's Avatar
Is there anyway that the logg button could be in the car like the subaru sti? They have the rear windshield heater button.
Also if it's possible to add like anti lag system so how to interrupt the spark ignition?
Mazdaspeed 6 2006
Sp63 Longblock with Mahle and manly, ported head, keyed crank and cams, stiffer springs, GTX2867R IWG, Freaks intake 4 inch,Autotech Internals, Stratified Ebc + GA, CP-E injector seals, CS Custom pipes FMIC, Snow performance stage2 100% meth, Cp-E decatted downpipe, Custom Catback with VareX mufflers, EGR Delete, SURE TMM+PMM+RMM, South Bend Clutch Stage3 Daily, CS rear diff mount, TurbineTech Front diff mount, CS rear swaybar, Racingbeat rear Endlinks, Matt Damond PS cooler, JBR OCC Stage 2, Bosch 3 bar MAP w/ PNP Harness, BC coilovers, Tenzo R Type M 19" 235/35, Sure Shortshift, Xcarlink, Speed performance Aux fan control, Synchronic DV BOV, DBA front rotor, Ebc yellow stuff(FR), EBC greenstuff (R), Stoptech brakelines and Finally, Tuned By Lex @ Stratified
Current INFO : tuning is paused due the winter.
Waiting to be installed: Cp-e exhaust manifold stock flange with MVR 44 external wastegate and dump tube.
 Old 11-04-2014, 10:11 AM   #14
Those buttons are not connected to the ECU. They are connected to the ICM. It would be a LOT of custom code to implement.
Spark cut is very hard on the cats and washes the oil from the cylinder bores. It might sound cool to pop pop pop, but it's hard on the equipment.
MegaSpool gives the spool you want while still starting combustion in the chamber where it belongs.
Steve
Lead Tuner
Easter Bunny (11-04-2014), leka (11-04-2014)
 Old 11-04-2014, 10:40 AM   #15
leka's Avatar
I hit 12 psi in the Lc with megaspool, I run 23 psi, is this normal? I have -25 on the retard for the LC, 5200 RPM with the supporting mods
Mazdaspeed 6 2006
 Old 11-04-2014, 10:52 AM   #16
Groans: 33
You might want to put your gtx2867 and other mods in your signature when asking questions like that or they will have a hard time answering
12psi sounds spot on to m
Mazdaspeed6 -06
290 AWHP / K04
 Old 11-04-2014, 11:23 AM   #17
leka's Avatar
I attached a log, the AFR is very weird
GTX2867 with Meth starting spraying at 4 psi
stock block with E85 (33%) and Europe 98
tuned by Lex
 Old 11-04-2014, 11:32 AM   #18
That log does not show MegaSpool active. You should see the negative timing in the log. Did you confirm that MegaSpool is enabled and reflash the ECU after you enabled it?
When it's active, you will know immediately. The engine will sound like it's bogging and will rev very slowly.
You will see the AFR spikes when LC is active because it is using fuel cut. Fuel cut lets air pass through the engine and not get burned with fuel. The O2 sensor picks up that oxygen.
Steve
Lead Tuner
 Old 11-04-2014, 11:41 AM   #19
leka's Avatar
Yes
Mazdaspeed 6 2006
 Old 11-04-2014, 11:42 AM   #20
What year and model is the car?
Steve
Lead Tuner
 Old 11-04-2014, 11:42 AM   #21
leka's Avatar
I'm flashing again
Mazdaspeed 6 2006
 Old 11-04-2014, 11:45 AM   #22
leka's Avatar
Mazda 6 mps 2006, I'm flashing again, this time I saw the megaspool activated just before the flash button, did not se it last time I flashed, it's about to finish
The clearing any diagnostic trouble codes take much longer time in this version of VT
Mazdaspeed 6 2006
Last edited by leka; 11-04-2014 at 11:45 AM. Reason: MSF Database - Automerged Doublepost
 Old 11-04-2014, 11:48 AM   #23
I think the slow clear DTC process may be a new bug. It may be taking too long to time out on modules that are not present.
Steve
Lead Tuner
 Old 11-04-2014, 11:59 AM   #24
leka's Avatar
its working!
see the log, did it for 2 sec, did not wanna any attention from ppl around me :p
The Following User Says Thank You to leka For This Useful Post:
 Old 11-04-2014, 12:23 PM   #25
Nice before and after.
Before: 5500 RPM 10.9 PSI Boost, 240 g/s Flow
After: 4800 RPM, 27.7 PSI Boost, 325 g/s Flow
That's how you launch an AWD Mazda
Rich990 and leka like this.
Steve
Lead Tuner
The Following 8 Users Say Thank You to Steve@VersaTune For This Useful Post:
Deldran (11-07-2014), Easter Bunny (11-04-2014), leka (11-04-2014), Micha (11-04-2014), phate (11-04-2014), Rich990 (11-20-2014), Roddiy (11-09-2014), TiGraySpeed6 (11-04-2014)
 Old 11-04-2014, 12:25 PM   #26
leka's Avatar
Mazdaspeed 6 2006
 Old 11-04-2014, 12:34 PM   #27
[R]usty's Avatar
Posts: 2,204   (View Stats)
This is very impressive, great job VersaTune team. Might be time for a change.
2010 Mazdaspeed3 w/tech
 Old 11-04-2014, 12:36 PM   #28
leka's Avatar
Should I make any changing in anything?
Mazdaspeed 6 2006
 Old 11-04-2014, 12:38 PM   #29
It's all about how hard you want to launch. If it's launching too hard, you could lower the rev limit and add a couple degrees positive timing.
May God have mercy on your diff mounts
Steve
Lead Tuner
The Following 4 Users Say Thank You to Steve@VersaTune For This Useful Post:
kgb (11-11-2014), Micha (11-04-2014), Rich990 (11-20-2014), SarcasticOne (11-04-2014)
 Old 11-04-2014, 12:41 PM   #30
leka's Avatar
I have upgraded both diff mounts, front and rear
So if I would like to launch harder, per say I could put more negative degrees like -27 or something?
Mazdaspeed 6 2006
 Old 11-04-2014, 01:00 PM   #31
If you're hitting your load target, you can leave the timing where it is. If you want more boost/load, turn up the load target. You only need to retard timing more if you're hitting the rev limit and not hitting your load target. If it seems like it's taking forever to rev up, you can add some positive timing. You'll have to experiment a bit to get it dialed in for your setup.
Steve
Lead Tuner
The Following 3 Users Say Thank You to Steve@VersaTune For This Useful Post:
Easter Bunny (11-08-2014), Koke382 (11-04-2014), leka (11-04-2014)
 Old 11-07-2014, 09:41 AM   #32
leka's Avatar
Hey man!
There is something I don't understand, I changed the Retard to -24, I tried to lower the Boost building up, and lowered the LC to 4800 from 5200, but i boosted as high as 29 PSI :p
I wanna run like 24-25 PSI
 Old 11-07-2014, 09:42 AM   #33
leka's Avatar
A log
 Old 11-07-2014, 09:58 AM   #34
Try -20* and see if that lowers the boost. What is your 1st gear load target at 4500 and 5000?
Steve
Lead Tuner
 Old 11-07-2014, 10:05 AM   #35
leka's Avatar
Mazdaspeed 6 2006
 Old 11-07-2014, 10:12 AM   #36
If you look at the log, you are just under 2.7 load. The ECU will keep the wastegate closed until you hit the load target - between 2.7 and 2.75 in this case. The only way to lower MegaSpool boost without lowering the load target is to add positive timing. Try -20*, then -17* then -14*, etc until you find the sweet spot where you hit the boost/load point that you want to launch at while hitting the LC limiter.
Steve
Lead Tuner
The Following User Says Thank You to Steve@VersaTune For This Useful Post:
 Old 11-07-2014, 10:15 AM   #37
leka's Avatar
Okay 👌 thanks for the quick reply!
Mazdaspeed 6 2006
 Old 11-07-2014, 11:31 AM   #38
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
@Steve@VersaTune;
Question about the odbc cable. It appears to be a straight "dongle" are there any options for this to be a right angle similar to the APv3.
With the speed 6 the odbc is extremely close to the peddles and I already worry about hitting it with my clown feet. If it came down further which it looks like the VT cable does it is a bit concerning. Just curious if you are aware of any other quality options for this.
Damond Built Speed 6
 Old 11-07-2014, 12:08 PM   #39
You can get a 90* adapter. Search for J1962 or OBDII right angle adapter on google/amazon/ebay. They're under $10 USD.
Steve
Lead Tuner
 Old 11-07-2014, 12:12 PM   #40
leka's Avatar
I tried with -14* and the boost is 26,5.
Will post a log in 2 min
Mazdaspeed 6 2006
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/versatuner-v1-9-released-179590/
VersaTuner @ therpmstore.com This thread Refback 05-27-2015 11:36 PM
VersaTuner 1.8.5 Released Steve@VersaTune VersaTune 28 11-03-2014 01:42 PM
VersaTuner 1.8.5 Released Steve@VersaTune MazdaSpeed 3/6 - ECU Computer Tuning 1 03-21-2013 09:45 AM
VersaTuner 1.8.5 Released Steve@VersaTune 2010 MS3 - ECU Computer Tuning 0 03-21-2013 09:04 AM
VersaTuner 1.7 Released! Steve@VersaTune MazdaSpeed 3/6 - ECU Computer Tuning 8 05-03-2012 07:20 PM
VersaTuner 1.7 Released! Ugnius@VersaTune VersaTune 0 04-25-2012 11:39 PM
Page generated in 0.58389 seconds with 30 queries
