  • 1 Post By Vansquish
  • 1 Post By MSMS3
 Old 03-15-2019, 10:10 AM   #1
Rizz Nasty's Avatar
Posts: 114   (View Stats)
Rizz Nasty has a brilliant futureRizz Nasty has a brilliant futureRizz Nasty has a brilliant futureRizz Nasty has a brilliant futureRizz Nasty has a brilliant futureRizz Nasty has a brilliant futureRizz Nasty has a brilliant futureRizz Nasty has a brilliant futureRizz Nasty has a brilliant futureRizz Nasty has a brilliant futureRizz Nasty has a brilliant future
Default Vtcs base tune
Anyone have a base tune for intake, tip, hpfp, catless dp, and vtcs delete?
Bone stock.....
Rizz Nasty is offline   Reply With Quote
 Old 03-15-2019, 11:33 AM   #2
Police - Grammarhead
Vansquish's Avatar
Yep. But you won't be able to use it.
Jeff23spl likes this.
 Old 03-15-2019, 11:37 AM   #3
Rizz Nasty's Avatar
Can't share tune's?
Sent from my SM-G960U1 using Tapatalk
Bone stock.....
 Old 03-15-2019, 11:41 AM   #4
Posts: 2,237   (View Stats)
why not using an ots stage2 if you cannot afford a e-tune ? The only possible problem is to try to run a larger intake...
Originally Posted by Rizz Nasty View Post
Can't share tune's?
No and unless you followed the class to get ATR (or you got it many years ago) you won't be able to have anyone else to change your tune than a registered cobb tuner.
Last edited by Jeff23spl; 03-15-2019 at 11:41 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-15-2019, 11:44 AM   #5
Rizz Nasty's Avatar
I'm running a cobb stage 2 map but it doesn't take into account the vtcs system at all, or catless dp(states catback). I'm playing with the idea of tuning myself, just wanted a better map to start with
Bone stock.....
 Old 03-15-2019, 11:47 AM   #6
Vansquish's Avatar
Nope. You need to read about how the AP and AccessTuner work. You cannot share tunes between vehicles unless you have a pro-license. You will need to either use an off-the-shelf map (not recommended), pay for ATR and pay for and take the FI course (somewhat recommended - depending on your skill level), or pay for a custom tune from a reputable E-tuner (highly recommended).
Thor Hammer (03-19-2019)
 Old 03-15-2019, 11:47 AM   #7
Rizz Nasty's Avatar
No shit. Yeah, last time I played with a Cobb tuner was 6 years ago or so.
Bone stock.....
 Old 03-15-2019, 11:56 AM   #8
Rizz Nasty's Avatar
So best e tuner?
Bone stock.....
 Old 03-15-2019, 06:31 PM   #9
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Where the fuck have u been for the last 8 years. VTCS delete can be taken care of with a relay FWIW. I hear Raceroots tuning is good...
MECP
2012 BM
Rfinkle tune in progress
 Old 03-15-2019, 06:45 PM   #10
Rizz Nasty's Avatar
Been rotating through BMW's. Then a speed6 fell into my lap, so here I am
Bone stock.....
 Old 03-15-2019, 07:51 PM   #11
Posts: 2,827   (View Stats)
Time for you to read some threads - real basic stuff, like how Cobb fucked everyone.
You will either need a good e-tune (many reputable choices) or switch to Versatune where you can self-tune and get support without paying a ransom for the privilege.
rgurleyjr likes this.
Initial Base Tune Fstrnyou VersaTune 8 09-20-2016 08:17 AM
Base tune, what does it do? Kor3y101 Gen2 MS3 General Discussion 4 04-12-2015 02:03 PM
Boost Tune - Only running base WGDC MattJackson86 MazdaSpeed 3/6 - ECU Computer Tuning 10 05-08-2014 05:13 PM
In need of BT Base Map Tune myfirstturbo MazdaSpeed 3/6 - ECU Computer Tuning 18 07-28-2013 02:34 PM
Not boosting even on base tune KRheeder MazdaSpeed 3/6 - ECU Computer Tuning 0 02-09-2012 01:27 PM
Page generated in 0.31620 seconds with 24 queries
