Like Tree3Likes
  • 1 Post By ms3blackmica
  • 2 Post By Doucems6
 Old 04-22-2013, 10:26 PM   #1
Doucems6's Avatar
Posts: 62   (View Stats)
Doucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond repute
Default WOT now super lean, high stft, and stalling at idle.
Hey guys did a few wot pulls with the bnr, everything has been running flawlessly for about 2 weeks, logs have been looking good up until tonight.
Car was pulling hard, then after data log, the cl driving became very stumbly! Once down to idle the car actually stalls out, trying flashing a new map the only code i had was u0100.
The first data log is before it started to shit the bed..
The second is a log of low rpm cruise with the current problem. Checked all conections everything looks good.
Ive noticed the commanded fp is way off from the actual , really high stft +25
and afr super lean in CL driving.
Please help me diagnose the problem I will be willing pay pal some money to whoever can help!
BNR stage 3 *cpe sri * sure TIP* sure TIG * Cobb ap * autotech hpfp * PNP IM vtcs delete *custom fmic 2.5" piping * optima red top trunk mounted *egr block off * moroso occ * ets cat-back * bosch 3 bar map sensor * turbosmart bov (recirc) * 3" m2 catless dp* grimmspeed 3 port ebcs* sure ssp* solid shifter bushings * ss brake lines * stoptech slotted rotors w/ oem pads* ngk 1 step colder plugs * mt 90 tranny & diff oil * front & rear strut tower bars * badge-less grill * evo x wheels * 225/40/18 nitto invo's * triple gauge pod autometer gauges*
*** Freak tuned ***
21psi
best 1/4mile----13.5 @ 104 mph 1500' above sea level
Doucems6 is offline   Reply With Quote
 Old 04-22-2013, 10:32 PM   #2
rtabagaboy's Avatar
Posts: 363   (View Stats)
Groaned at 7 Times in 3 Posts
Blew a boost tube maybe. Vacuum leak taking in un-metered air? Looks like your MAf is getting a little crazy for a crusing maybe a loose connection.
2008.5 BlackMica Mods:
AZ Status!
 Old 04-22-2013, 10:33 PM   #3
snailD's Avatar
Posts: 3,039   (View Stats)
first off what are u commanding for afr and your maf sensor could be going out. i would reccomend cleaning it with maf cleaner and see if that helps. looking at logs now..
rfinkle2 (04-23-2013)
 Old 04-22-2013, 10:42 PM   #4
Doucems6's Avatar
Thanks , I actually cleaned it a few days ago and its been fine since then, lots of wot runs since then. Checking fuses now! Could it be a relief valve? Ive been following abilors guide, so 14.7 CL and ive been commanding 10.90 and actual AFR has been about a full point leaner.
ex. command 11.00 actual 12.00
rechecked maf connection, going to look for vac leaks.
*** Freak tuned ***
21psi
Last edited by Doucems6; 04-22-2013 at 10:42 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-22-2013, 10:49 PM   #5
snailD's Avatar
it has to be something involving airflow. u said u checked all the intake components? what about exhaust leaks, primary 02 could be on the fritz, the tune has stayed the same yes?
 Old 04-22-2013, 11:06 PM   #6
Doucems6's Avatar
just checked all fuses except the 2 I wanted the must fuel pump and inj. They are the 30amp fuse but are a solid colour couldnt tell if they were blown. The code it threw said the description read :
Lost Communication with engine control module/powertrain control module.
Tune was slightly different added .5 more psi (commanding 18.5 psi) and added some fuel 11.00 - 10.90.
I am catless and have the cat code deleted. It was completely fine for one other wot run. the second log ( good log listed here) was also perfect ! it was the low throttle driving right after started to fluctuate. stopped then couldnt hold idle stalls every time. It will drive but have to stay on the gas.
*** Freak tuned ***
21psi
 Old 04-22-2013, 11:14 PM   #7
snailD's Avatar
hmm, have you tried resetting the ecu by unplugging the battery?
 Old 04-22-2013, 11:27 PM   #8
Doucems6's Avatar
I did once but may be i never left the terminal off long enough. I'll do it again.
AND im so close on the list to a atvfreek tune, I've been inline for a while.
Im thinking the maf might be ok i had one fail before and the car was way more uncontrollable.
def leaning more towards the o2. I just cant see what could just make it fail out of the blue.
*** Freak tuned ***
21psi
The Following User Says Thank You to Doucems6 For This Useful Post:
 Old 04-23-2013, 12:14 AM   #9
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
If it is actually a leak it is sucking in air.
Prime culprits would be:
1) Check the TIP to turbo connection.
2) All vacuum lines
3) MAF sensor. If the MAF does not sit flush it will not meter properly.
Also, if you have a PnP intake manifold what did you use to plug the hole on the side of the manifold where the VTCS rod used to go?
Many people use JB Weld and it does pop out sometimes..
www.tunedbynishan.com
The Following 4 Users Say Thank You to ms3blackmica For This Useful Post:
Doucems6 (04-25-2013), phate (04-24-2013), rfinkle2 (04-23-2013), Voltron (04-23-2013)
 Old 04-23-2013, 09:37 AM   #10
Doucems6's Avatar
Status update: went to start the car this morning. Ran for about 3-5 arcs and stalls out. Going to do more vac/ mani inspection s after work. And order a new purge solinoid and may be relief valve.
*** Freak tuned ***
21psi
 Old 04-23-2013, 10:11 AM   #11
OP, can you post your map when you get a chance?
 Old 04-23-2013, 10:56 AM   #12
Doucems6's Avatar
I only have one other really long data log of when I managed to limp it home! But I will post it when I get off work. I have a purge solenoid on hold picking up afterwork. Thanks for your intrest I appreciate it guys this is my dd.
*** Freak tuned ***
21psi
 Old 04-24-2013, 02:12 PM   #13
fastblueufo's Avatar
Posts: 17   (View Stats)
fastblueufo is infamous around these partsfastblueufo is infamous around these parts
Groaned at 87 Times in 12 Posts
You could have a leak pre turbo as your stft is pegged at 25%+. Your hpfp pressure looks low at cruise and 2100 rpm. But it could just be how it is tuned. Looks like fp is fluctuating more than normal for the minimal amount of load and map change.
fastblueufo is offline   Reply With Quote
The Following User Says Thank You to fastblueufo For This Useful Post:
 Old 04-25-2013, 04:49 PM   #14
Doucems6's Avatar
2) All vacuum lines
You nailed it bud! I searched the car top to bottom for leaks, sure enough i found a strange looking piece on my tranny and it was the one opening we used jb weld on the plug for the vtcs rod! placed it back in to see if that was the leak. sure enough the bitch fired right up and ran flawlessly. So we removed it again and tapped it used a pipe plug and vola the tuning continues.
pm me your paypal address so i can hook you up with a few bucks!
To everyone else thanks so much for all the help, now i know what to look for next time im wot with problems lol
rfinkle2 and ms3blackmica like this.
*** Freak tuned ***
21psi
The Following 5 Users Say Thank You to Doucems6 For This Useful Post:
Miltron (11-04-2014), mr.speedy3 (09-21-2014), ms3blackmica (04-25-2013), Pointless (04-26-2013), rfinkle2 (05-28-2013)
Almost stalling at idle Mandinca MazdaSpeed 6 - Engine, Transmission & Driveline 20 02-26-2013 07:01 AM
high idle STFT.. purge valve OK mrQQ Mazdaspeed3/6 General Discussion 15 08-10-2012 03:17 AM
High STFT at idle... Intermittent fault. KevMS6 Mazdaspeed3/6 General Discussion 11 07-24-2012 06:34 PM
wtf super lean at idle ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 30 03-20-2009 07:40 AM
Page generated in 0.35844 seconds with 26 queries
